Displays VLAN statistics at the VLAN level.
| vlan_name | Specifies to display VLAN statistics from the VLAN with this name. |
| vlan_list | Specifies a VLAN list of IDs. |
| no-refresh | Specifies that there is no continuous refresh. The prompt comes back to the user after fetching statistics once. |
N/A.
This command displays statistics based on the sum of the statistics for individual ports. Use it to display the VLAN statistics monitored using the configure ports [port_list|all] monitor vlan vlan_name | vlan_list {rx-only | tx-only} command.
The following command displays VLAN statistics:
# show vlan statistics Vlan Rx Total Rx Byte Tx Total Tx Byte Frames Count Frames Count =============================================================================== Default 30251013 7326296 22034 901840 =============================================================================
If the VLAN contains ports that do not support a certain type of VLAN statistic, such as transmit statistics or byte counters, then a dash character ( - ) will be displayed in that column.
This command was first available in ExtremeXOS 12.0.
Support for ExtremeSwitching series switches was added in ExtremeXOS 12.5.
The no-refresh keyword was removed in ExtremeXOS 16.1.
The vlan_list variable was added in ExtremeXOS 16.1.
